toyota truck has me bum fuzzeled
scottsville ky
I bought a 92 toyota 4x4 truck the prior owner had the original fuel injected engine and had approxamitly a 1985 carborated engine put in it.I drove it fof bout a year with no problems now when I can get it to run for about an hour justat an idle when it dies the gas in the bottom of the carb sound like it is boiling I have replaced fuel pump 2 carbs 1 intake each time I did that it ran for a couple days then the same thing happens. once it dies it will turn over like it going to start but that's it. sure could use some help
Vapor lock is when buggy is driven during hot day, then sits in hot sun for 1/2 hour. Engine heat boils away all gas in carb. When started after this hot-soak, fresh gasoline entering carb also boils off for a bit until evaporative cooling (& poor running) cools off components.
I put a different gas line on the fuel pump and run the gas line into a 5 gal. gas jug it ran for 30 to 45 mins. then it died and wouldn't start again until 2 days later it does that over and over again.
