toyota parts
I have the fallowing parts for sale the parts are for 84 and 85 unless noted located in southern Ca 91768:
1- Bech seat needs to be clean up $20
2- Jerry Gas can Red metal $10
3- Jerry gas nozzle metal large $5
4- Jerry gas nozzle metal small $5
5- 2 open differentials no R&P $20 each
6- Break and Cluch bracket with break pedal $10
7- Fuel vapor canister $7
8- 2 Ring and Pinion 410 $40
9- Driver side headlight bezel black $7
10- EFI fuel hose $10
11- Driver side and passenger side seat belts $17
12- Brake release lever with brake signal $10
13- Steering shaft with knuckle $15
14- stereo, ashtray plastic cover $10
15- Hood latch and arm $12
16- outer plastic cab ornament black $7
17- Used EGRV $10
18- Hood latch $10
19- 3 steering box mounting bracket $7
20- take off clucth assembly $20
21- horn $5
22- horn from a 92 $5
23- 4 bump stops and 2 from a 92 $5 each
24- IC regulator used $10
25- Spare tire lift from a 92 $10
26- 2 Wiper motor $15
27- Driver side mirrow casing no mirror from a 92 mini $5
28- steering knuckle plastic protector $5
29- 2 coil igniter $15 each
30- brake release lever $10
31- fan $15
32- 2 motor mounts $15
33- 2 ash trays $5 each
34- fan pulley $7
35- water pump used from a 83 $7
36- 3 windshield washer motor $5 each
37- 2 turn signal housing and lense $5
38- 2 sun visor grey $7
39- 2 wiper arm $5
40- 22 r engine control $20
42- fj40 trun signal arm $10
43- bridgestone dueller h/t 31x10.5x15 $15
44- one wells wheel 10x15 $50
45- passenger side fender 2wd from a 92 white $30
46- passenger side window glass 2wd 92 $10
47- passenger side complete door and glass 2wd 92 white $50
48- complete rear axel 2wd 92 $75
49- 2wd 92 hood white $30
50- hood blue $30
51- gas tank $25
52- 2wd 92 gas tank $25
53- fj 40 half hard doors $200
54- fj 40 rear lift hatch no glass $75
55- con-fer jeep box installs behind the rear seat $100
56- large steel fuel cell $25
57- toyota valve cover $25
58- a/c hose and lines $15
59- tilt steering wheel and colum $75
60- 2 coolant over flow bottle $ 5 each
61- brake resevoir cap with plug $5
62- cluch cylinder used $7
63- 2 hood hinges $10
64- hand brake adjusting lever $5
65- 2 accelerator pedals and mounting bracket $7
66- complete wire harness for a 84 mini $20
67- oem stabilizer bar $10
68- rancho stabilizer bar $15
69- 2 power stering box $40
70- drive shaft from a 2wd 92 $15
71- used brake booster $10
72- non power steering box for a 92 $15
73- 2 Air blower $15 each
74- 2 a/c condenser $40 each
75- 2 heater core one $15 and one $25
76- a/c heater control with faceplate $20
77- steering colum non tilt $25
78- a/c heater control $15
79- miscellaneous vents $5
80- glove box $7
81- 5 speed 2wd trans from a 92 $100
82- MAF from a 92 $15
83- 2 dash clusters $20 each
84- miscellaneous dash panels
85- 2 a/c evaporator one $30 and one $40
86- 2 a/c receiver dryer $15 each
All prices are with out shipping I can send pictures if requested. Thanks
the fj-40 doors, year and condition at the bottom, dents, rust etc. Interested... thanks Ken
