I have a Toyota pickup bed trailer (on the truck frame)....I estimate it to be off of a '86-ish truck. I want to run the lights so that I can utilize the stock light assemblies with the amber turn signals, the back up lights and, of course, the tail and brake lights. That can wait for later and I'll probably need some help with that......
Right now, though, I just have to get the lighting hooked up to be legal. For now, I picked up a 4-pin flat connector set up.
I understand that:
1) the yellow wire is for the left turn signal and the brakes
2) the green wire is for the right turn signal and the brakes
3) the brown wire is for the tail lights
4) the white wire is the ground
I also bought the 5-wire to 4-wire converter and have that wired onto the wiring harness of the 40. So far so good.
When I hook into the trailer light assemblies, with the 4-pin connector, the brake lights will ALSO be the turn signals (the amber lights won't operate). Is that correct or am I thinking this through incorrectly?
Assuming I'm correct, I want to splice the yellow and green wires into the brake wire on the tail light assemblies (left and right respectively) and the brown wire into the tail light wire, right? Do I need to run the brown wire to only one or both of the assemblies? (Sorry, I'm really bad at auto electric stuff).
Am I missing anything here or should this work? Any feedback would be greatly appreciated. I need to get this thing on the road tonight, if possible.
Thanks in advance
I understand that:
Thanks in advance
