- Location
- United States
This type of tool kit and accessories were standard equipment in mid-70s-early 80s Land Cruisers. The kit is complete and includes all vintage Toyota tools, except for the hammer, which is new. Also included are the brown, cast jack handle, small can of touch-up paint and black inspection lamp with blue bag.
Overall, the tools are in very good, used condition and reflect light use. The tool bag is in very good condition and has stains and marks from age and use. The jack handle finish has chips and marks from age and use. The blue bag has stains and marks from age and use. The touch-up paint can is intended for display only, the contents of the can are unknown. This kit includes a 3-wrench set instead of the original 2-wrench (10x12mm, 14x17mm) set.
The kit includes the following pieces:
- Pliers (200mm) marked Toyota, with dimples grip
- Lug wrench (21mm) 2-piece, marked Toyota Motor
- Adjustable wrench (250mm), marked Toyota Motor
- Spark plug wrench (20.6mm), marked Toyota Motor, formed socket with separate handle
- Screwdriver, yellow plastic handle marked Toyota Motor, with reversible flat/cross-head shank
- Open-end wrench (8x10mm), raised handle, marked Toyota Motor and Special Alloy
- Open-end wrench (10x12mm), raised handle, marked Toyota Motor and Special Alloy
- Open-end wrench (14x17mm), raised handle, marked Toyota Motor and Special Alloy
- Red wrench clip (3-wrench set, original kit had the 2-wrench clip)
- Wheel cap wrench, long rod with the flattened tip
- Wheel cap replacer, black vinyl coated bracket
- Toyota hammer, new, not vintage
- Toyota Motor tool bag with YKK zipper
- Toyota touch-up paint can (140ml)
- Toyota inspection lamp, this is the yellow-zinc finish version with 1 hook
- Blue bag for the inspection lamp, marked with the TEQ and TR (Tokai Rika manufacturer) logos
- Toyota brown jack handle, original finish (30cm)
