Toyota diesel conversion
Maple Ridge, BC
So to start i have a 74 FJ40 with a F and H42 4 speed tranny. I would like to stick a toyota diesel into it, maybe like a 3B or something. I'm not too up to date on the toyota diesels. So I have a few questions...
(1) Will any of the diesels bolt up to my engine mounts on my frame?
(2) Do I have to get a new tranny?
(3) Can run saginaw steering with toyota diesels?
So I was wondering if there was a diesel i could drop into my cruiser. Any info would be great. Thanks
BC; i know that the h series diesels share the same bell-housing/ trans input as the f, but the b motors are diferent (longer bell/ fine-spline trans input).
try searching/ posting in the international section, we never got any toy diesels here in the states.
HTH, carl
Ya i doing some crazy researching right now, and it does look like the F and H do share the same bellhousing and tranny input. I'm thinking a 2H , 1HZ, 1HD, or 1HD-T would bolt up to my tranny. If I'm wrong please correct me, I'm still learning here.
Why not go chat with Greg and Sheldon at GS Cruisers in Abbotsford.
stephen said:
i have 69 fj40, w/ 1B diesel engine 5 speed transimission 3speed xcase, as to your 1st question, motor mounts not d same, fabricated new one. 2nd, i used the 5 speed transmission attached to the B motor. hope these ideas can help
How about telling us how you attached the 5 speed to the 3 speed transfer case? I know they will bolt together but there are no gears available to mate them as far as I know.
I'm working on this now ( 3B into 74 40 ). Bell housing different trans input different. Maybe the biggist issue is vacumme for the brakes at least it has been for me. Origional Toyota diesels had a vacumme pump on the alternator but these are pretty rare and very expensive.
Toby--there've been some discussions of vac pump alternatives on the Int'l Board. If you go over and do a search for "vacuum pump" a whole bunch of stuff comes up. A lot to sort through so I couldn't post just one thread as a link here.
HTH
:cheers: B
F series to 3B swap
Use the Toyota 3B diesel engine with the H41 transmission and get the motor mounts and fan shroud with them, and it's a pretty straight forward conversion. I am putting said combo into a '64 FJ45 LWB pickup, and all that is added is a toggle switch to turn on the glow plugs and a push/pull fuel shut off to kill the engine. The 3B gets about 30 MPG, and is nice and torquey. If top end is lacking use a torque-splitter with 27% overdrive.
I installed a complete 1983 BJ60 motor,5 speed transmission and transfer case as a unit.I had to move the front mounts back and make a tranny mount.Then i had one drive shaft made shorter and one made longer,works great,real good mileage and nicer drive on the freeway.
Wayne
