Hello, I’ve been troubleshooting a white smoke scenario at idle and beyond. Recently a lift or feed pump was brought into question. I did not know the vehicle was equipped with an initial lift pump. And cannot find any literature regarding placement to confirm. I suspect some issue with pump systems. But have been focused on HPFP and injection.
Any insight into hp fuel systems appreciated if anyone has experienced similar conditions. I live at significant elevation, 9000ft and am thinking to adjust timing / plunger depth. I’ve read researched about Advancing timing for elevation. Currently plunger depth is 1.5mm At TDC. spec is 1.35 felt like advancing further would be too far so not sure about timing adjust now.. Truck was imported from firetruck usage at similar elevation in Japan. Think maybe it was adjusted already for that elevation. Picture of my Fuel pump . It’s sitting at a diesel injection shop that’s far more familiar with Cummins and Bosch and is not keen to work on this one. also pressure testing the injectors to confirm.
Been through most the rest of truck and running out of ideas..
