Toyo MTS 295 70 18 and slee lift
NW
I tried on the tire and it only rubs on the KDSS bar at full lock. I don't have issue with slight rubs, as my Tundra's 35s rubbed on the stock front sway bar. I just did not fully lock the front well and if I did it knew what was going on. It looks great and I love the MTs. I k now many folks go with Nittos. I have not purchased them. Any thoughts on this set up and the rub?
I'm not familiar with that set up , but I did hear SLEE makes some KDSS relocation bracket to fix that issue. I also heard the owner is running 35's and no lift.
What is a SLEE lift?
2 to 3 inch lift
The lift itself causes some inward clearance issues itself, such as against the KDSS bar. Because the lower control arms are no long relatively horizontal, they travel in an arc, and bring the tire inward relatively more with lift.
KDSS relo might be an option.
What type of wheels (offset?) are you on? Wheel spacers (.75") could be an option too.
1.25 spacers.. Tundra trd pro rims...
