Toybox questions
First off, I've read several other posts, which helped me with my post, but some of this may have already been asked.
I’m going to be getting a 4.7 Toybox soon, but I have some questions. I have an SM420 with the 3-speed transfer case. I know they are a bit weaker then the 4-speed case and the split case, and I’ve been told that I should upgrade to the split case (which brings up the whole e-brake issue), but I’m wondering if I really need to. I have the stock 6 cylinder so I don’t have a lot of hp hitting the axles and even though I run the Rubicon and Fordyce Creek etc., I don’t beat my cruiser (e.g. minimal wheel hopping and bouncing). Is an SM420/Toybox/3-speed case a set up waiting to break or does horsepower and driving style make a bigger difference? I have no problem upgrading, I just don’t want to simply “because”.
Is there a transfercase saver available that will fit once the Toybox is installed?
Also, besides the obvious, like a new rear driveline, what other modifications are necessary for this upgrade? I’ve heard that a crossmember may have to be cut and lengthened, that the transmission hump may not fit, that the gas tank may need to be removed, etc. Any “gotchas” that I should know about or any important issues that I didn’t ask about? I’m an avid 4-wheeler, but not a mechanic so I could be missing something obvious.
I’ll be flipping my rear leafs at the same time, but I know what’s involved with that.
Thanks,
John
Crossmember will need to be removed/relocated.
Fuel tank in your application should not need to be messed with, since your truck is a 1978. 1979 and later 40 series tanks are under the truck and in the way...
The one piece Land Cruiser case may last forever behind a 420 and a 4.7 toybox in a perfect world...I would not bet a dollar that it will however...A case saver can be added and if you are really intent on running this combo then I would get one.
Yes the split case is stronger, and yes, you can get a parking brake kit for them, along with a set of crawler gears from Marks in AU too.. ;)
As far as other things that you will run into...Your floor/tunnel will need to be modified..and you may want to look at installing a bod lift to give things a little more room...
A 2.28 Toybox and an Orion would be a better combo...but to each their own.
Good luck!
-Steve
Poser, will the covers etc. from the three speed t-case work with the Orion?
From a dollar and cents point of view could you get into an Orion for what you would spend to buy a four speed t-case and re-build it?
Edit: The sm420/toybox/orion would give you some crazy low gearing options.
IF YA HAVEN'T GOT THE TOYBOX YET.... F Y I .....
ONE IS FOR SALE HERE ON MUD,
CHECK OUT PARTS FOR SALE ,,, JUST INFO !
GOOD LUCK ....:grinpimp:
