Toy Box Removal.
Reno, NV
Website
forum.ih8mud.com
I want to fix a small oil leak between my Toy Box and transmission while I have the gear train out of my 40.
But I cannot get the two apart, I am totally stumped.
I tried more beer but that just lead to a nap.
Any other suggestions?
I believe it is only six bolts you need to remove from the adapter plates to split the two. See the URL in my signature for directions on how to put the Toybox together and go backwards on the step where I install the plate adapters to the tranny then join the two.
Doing it this way you will have the tranny with the plate adapter on it and the toybox will still be connected to the xfer case.
I have the six bolts out.
Nice write up on your site. I read it, along with Marlins instructions before I put this set-up together. After reading it I wussed out and had a transmission shop replace the O/P shaft on my transmission. :D
It is likely just the silicone keeping the two plates together....
There are only the six bolts retaining the Toybox to the adapter on the back of the trans...
:beer:
:beer:
I seem to re-call it taking some finagling to get the T-case off.
I noticed a couple of depressions milled into the Transmission adaptor plate on the Toy box side in the pictures on Johns site. I'll try a little prying action on those tonight
Figured it out.
Marlin provides two reliefs in the bottom side of the adaptor plate. Mine were filled with RTV so I didn't see them. I noticed them when I was looking at John's toybox install web page (where I also lifted the pic below).
By wedging two screwdriver blades in and tapping the handles I got the plates apart. As Poser thought the RTV was all that was holding the assembly together, once it started to seperate the whole thing came apart easy.
