Towing With the 40
Anchorage, Alaska
Probably chat, but I did some towing today with the 40. Here are my impressions.
First off the trailer is a 5x10, Single Axe, Haulmark Cargo trailer
Loaded with 1600 lbs. of gear, tools, generator, heaters, compressor.....
Cruiser, stock F motor, stock 3 speed tranny on 32" Nokian Tires
Conditions -17F this morning on the hillside of Anchorage, Icy roads with spots of loose sandy snow.
Driving time and miles, 38 miles total with many stops so my time was about 2 hours total out and about. Actual driving time was only 50 minutes or so.
The spot where I had to drive her was up on the hillside of Anchorage, not high as far as altitude goes but steep road going up and then unplowed road to the site I needed to get. Snow depth there was about 18". I was wondering how the rig would tow and was pleasantly surprised at the ease of which she did. Braking with the stock drums was a bit more work then I would like with the extra weight behind me. The 40 was easily pushed a few times by the weight. But she still stopped mostly straight and true. Once a car pulled out in front of me on a surface street and I had the need to hit the brakes quickly. That gave me a scare, she slowed though pulling to the right. As far as pulling the trailer down the unplowed road, my speeds were obviously reduce to 15 sometimes 20MPH and at those speeds I didn't even know the trailer was there except I couldn't see much behind me.
So... a few things I now need to take care of. I need to get better mirrors. I want to double check my brakes as the one time they pulled to the right they did so with some force. Not sure why I don't feel them pull when I brake normally. I do feel it pull when I hit them hard. I'm extremely happy with the power though. Even going up the steep grades she chugged along just fine. After all these things are as I've become fond of saying are not slow cars they are fast tractors. That is just fine by me.
Ok... if this needs to be moved then I'm sorry. I just thought it may be interesting to some.
Have a good day.
Maybe you had some wet brake shoes from driving through the deep snow? Glad the overall trip was good................and safe;)
Ed
....The 40 was easily pushed a few times by the weight. But she still stopped mostly straight and true. Once a car pulled out in front of me on a surface street and I had the need to hit the brakes quickly. That gave me a scare, she slowed though pulling to the right. .........
I do a lot of trailer-towing and I find that this is almost the only time I get braking faults showing up.
I think the extra "push" from the trailer magnifies and tendency of the brakes to pull left or right.
(But then on a snowy road, the "right pull" could be caused by your left front wheel having more snow/ice under it????)
I used to have quite a bit of oil/grease on the outside of my brake backing plates from weeping knuckle seals. - Probably because I like the grease in there to be sloppy. (I sometimes squirt EP90 oil in when I see the grease becoming dry.) But somehow this oil/grease was finding its way inside the front brake drums causing a left or right pull.
Now that I keep those backing plates cleaner the problem has disappeared.
But for me this problem normally occurred when braking down long steep gradients in HOT weather towing a heavy trailer. (Not in cold snow conditions.)
But it is possible melting snow is somehow washing oily residue inside your drums.
So my advice is to keep your backing plates free from oil and grease as much as possible. (And make sure the rubber plugs aren't missing from the brake adjustment slots because without them stuff could enter very easily via that route.)
:cheers:
Actually didn't think about the snow getting into the brakes... that is a very real possibility as the hard braking happened on the way home. I'm very confident in the seals, rubber plugs and know there isn't any goop or oil in them. That was what had me puzzled. I think I will still double check the adjustment.
thanks for the suggestions.
I was told somewhere on this site to NEVER put gear oil in my nuckles - it dilutes the grease and the mix cannot stand the pressure that the Birfields work under, or something.
Well whoever said that was talking rubbish in my view.
Grease is basically oil mixed with soap (thickening agent) to form a paste. In time the oil tends to escape from the thickening agent so that what's left becomes much thicker and less able to move around to where it's needed.
My grease guns are hanging in my garage and they regularly drip "clean oil" onto the workbench below (as the oil leaves the grease inside the guns).
I use black/grey molibdinum disuphide grease in my Birfields and this grease is particularly prone to "drying out".
The "EP" in gear oil means "extreme pressure" too!
I'm certainly not infallible but I do reckon I know what I'm talking about here. There's a lot of written info on MUD (and anywhere else you look - even Workshop Manuals!) that is incorrect.
I try to add only sufficient oil to return the grease to its correct "ex-cartridge" consistancy. (If it is too sloppy, it will run out the "swivel seals" too readily.)
:cheers:
Hey. Maybe we should start a new thread on this one and argue it out?:D
