Towing landcruiser
Roseville
Does anyone know if you need to put the tcase in nuetral when towing a FJ40 cruiser? I was told that damage can occur to the tcase if it is not in nuetral???
Is this true or just a cruiser myth....
Thanks
Fman
towed my 40 from seattle to salt lake city. yeah it needs to be in neutral.
Put the tranny and t-case in neutral and make sure the hubs are unlocked. I've seen a few people blow some stuff up by accidently forgeting one or the other :doh:
I did not put the Tcase in neutral for years ,also had plates in the front axle until the dics brake conversion with out any problems flat towing many miles. but it is a very good Idea to disengage everything. I once left a campground and the 40 was behind my camper. It was towing very hard at about 25-30 mph. when I checked it out it was in 1st gear. Luckly no engine damage.
I was towing a fj55 with trans & TC in neutral with the hubs locked, I lost the front TC bearing because of low gear oil and the rest of the TC gears were not slinging any oil with it being in neutral.
If gear oil levels are up you are fine IMO, but why chance it.
Thanks for the help. I think I will play it safe and remove the rear driveline, a little piece of mind... would hate to grenade a t-case from a new rig I just purchased.
