Towing capacity?
I don't think there's anything mechanical you need to change as the 80 is rated to pull substantially more than that everywhere else in the world. The problem seems to come from Toyota USA being overly worried about getting sued.
Even my old mercedes saloon was rated to tow almost 5000 pounds... :D
I've pulled an 8000 lb trailer all over the northwest with an F350 diesel, enough to get into some braking situations i wouldn't want to repeat. No way would I ever ask my 80 to try to stop 6300 lbs, even with trailer brakes. Not safe. period. And that's not even considering the lack of uphill go and the safety problems going 25 MPH would create. I'm comfortable with around 3500 lbs max, with trailer brakes. Uphill speed is compromised with with my little boat that weighs 1200 lbs. The sequoia would be a good choice, but there is no substitute for diesel torque and leaf spring rear suspensions once you get over 5000 lbs of trailer weight.
Just my humble 2 cents, disregard as you see fit. I know some members here do tow heavy and seem to do fine.
Upgrade your brakes and suspension if you want to do it more safely. More power would be nice. The Kaymar tow bumper is rated for 7700lbs.
I have towed a heavy tandem axle car trailer with no problems all the while remaining cognizant of the increased distance needed for braking.
