Towing and Issue
Kuwait
Close to 2 weeks ago I worked on a project for my brother. He signed up to take his Honda S2000 to the Bahrain International Circuit (the Formula 1 track in Bahrain) as part of the GulfRun and see what times he can achieve in his car.
The project was to put together a trailer in which we could haul gas, tires, and parts. I ended up calling around looking for old horse trailers and trailers that looked like the U-Haul ones but the cheapest I could find was KD1,500 (approx. US$5,500). What ended up was that I went to the junk yard and found an old 67 stepped Chevy pick up truck and turned it into a trailer! So far it cost a mere KD500 (approx. US$1,833)!
We didn't have time to properly paint the thing so we put one cut of black paint and printed out stickers for my brother's tuning company and stuffed the bed with 300 liters (approx. 80 gallons) of what we call Ultra Super gas, tires for my bro's S3K, tires for a Ferrari 360, brake pads for the S2K, fluids of all sorts, and tools. Oh not to mention 8 cases of the energy drink that help fund the event my brother signed up for.
Anyways, I was towing the trailer in 2WD but my brother told me to switch to 4WD and I did. Everything was ok until 2/3 of the way when we were in Saudi Arabia, close to Bahrain, I took my foot of the acceleration pedal and I heard a horrific grinding sound that occurred for a few second. That sound did not happen every time I took my foot of the pedal but it did happen quite a few times. Anyone know what that could be? I haven't taken my cruiser in for service yet due to the fact I still have about 1000KM to go! The cruiser runs fine and I have no issues with it now nor did I have any issues while towing the trailer in 2WD! The noise only occurs in 4WD!
Here are a few pics but please excuse the bad quality!
Before Pics :
After pics:
THE ONLY PIC OF THE CRUISER AND THE TRAILER :
I just found a pic of the cruiser but without the trailer! Thought it would be some eye candy! ;p
If it NEVER happens in 2WD, but does happen in 4WD then it seems to me it must be the front axle. Are you sure the front diff is full of gear oil, because this could be a badly stressed front axle gearset that may have been previously damaged. When you decelerate using the gearset, it switches from pressing against the drive side of the gears to pressing against the angled coast side (weaker, but easily strong enough for this unless damaged in some way).
If I were there, I'd first drain the front diff and look for excessive metal shavings (some are normal) or metal bits indicating gear damage. Then refill (be sure the fill plug is loosened before draining or you could be stranded and unable to fill). I'd also be sure the front driveshaft does not have a damaged CV joint or one in need of grease. I'd also drain and fill the transfer case - again looking for metal.
Hope your trip continues safely.
DougM
My trip went well! I went to Bahrain and back with this grinding noise being the only issue! Thanks for all the input and I will check out the items you mentioned. This might be the time to re-gear to 4.88 as well!
So is your truck a part time four wheel drive version then? If so... why put it in four wheel drive on clean pavement if you are not getting any wheel slip?
On the part time four wheel drive trucks, does the center diff lock when it is placed in four wheel drive?
If you have a part time system...
My understanding of this is that you need to rotate the hub locks on both front wheels to engage the front drive flanges. Then if you push the '4x4' button on the dash to release power from the transfer case to the front axle.
Were you driving with the button pushed but the hubs disengaged? Were they potentially partially engaged? I.e. could they have been turned to where they were scraping/grinding the edges of the lock out hubs?
I do not have a part time system, so I'm speculating a bit above. It may be something to check into.
I do have a part time 4x4 and my cruiser is unlocked! I don't even have the 4x4 button you're talking about and I don't have hubs either! All I have is the manual transmission shifter knob and the knob the has 2WD, 4HI, N, and 4LOW!
I'm not familiar with that system.
My best guess would be that in 4HI the transfer case is locking the front/rear. Although some debate this, I don't think it is a good idea to use that setting in high traction (on road) situations. It could result in some driveline binding as it forces a wheel to slip when turning.
Can you describe the grinding sound? Was it metallic or could it have been tires squibbing?
I would say metallic since that's what it sounded like and I don't know what tire squibbing sounds like! Kinda sucks that I'm not as savvy about this kinda stuff as the rest of you!
I'm just a rookie at this. My questions are more aimed at making sure that the pros have as much info as they can get to make a real diagnosis from. If I give any bad information, someone please point it out quickly.
A quick check to narrow things down a bit. Have you removed the front drive shaft lately? Be sure to mark the flanges & slip yolk before you do so that you get the alignment right later when you put it back in. Inspect the U joints for play and grease them (easier with it out on some of these).
Then test run it without the front drive shaft. Try it in 2wd and 4wd high to see if any noises. The idea here is to eliminate the transfer case as a possibility. (It isn't likely it, but since you'll have the DS out anyway, may as well.)
If the drive shaft looks fine and the tcase has been eliminated, then it is likely in the birfield(s) or drive flange(s) or the ring & pinion. At this point, hope for drive flange or birfield. To find out requires servicing the front axle. You will likely want to get your hands on a FSM (Factory Service Manual) for your truck. Since it isn't a US truck and clearly has some major mechanical difference to US trucks, I'm not sure where to point you to for it.
Thanks again for all the help! I was given 2 different repair manuals by a friend when I first bought the cruiser! With those 2, the FSM, and a good mechanic the issue should be resolved!
