Towing a 40
Dallas, TX
As a new owner, I am still learning about Cruisers. I want to get my 40 away from Dallas for hunting, wheeling, etc. Searching threads, I can't find an answer to my question; can you tow a 40 with just a tow bar? My tow vehicle is a 1/2 ton 4x4 Sub with a 350.
Of course!
You can tow an FJ40 with only a tow bar and safety chains and tow lights.
I am sure trailering is always best but not required.
I have a GMC Yukon that I use to tow my 78 FJ40 all over. You can't hit the corners too tight though... the cruiser might try to turn the other direction and then you have to stop and straighten them out.
In my 73 FJ40 I used to have I could run the seat belt through the steering wheel and buckle it to keep the wheel straight. This would allow it to track well. I don't know if it is a bad idea or not.... It just helped to get the cruiser home.
After years of going back and straighting out the wheels my son who has watched me do this was driveing on day and just backed correcting the fj as you would a trailer and took right off with out having to get out of the truck.
Did he have a look of statifaction on his face.
Here we go again, lots of treads on this one and opinions, IMO tow bars a fine if you do not mind 2 tons pushing you to a stop, thus a bigger rig is better.
I do haul mine with a tow bar and also have a 14 foot trailer with brakes I with.
no probelm either way. I perfer just the trans in neutral but make sure there is nothing that can fall on the shifter which I did have happen once when leaving a camp site. no damage but a little scarey.
keep inmind if you are lifted at all that you need to have your camber adjusted correctly or your fj will like to dart around behind you.
