towabilaty
It is possible, it has been done, it is not recommended without removing both driveshafts. There are several threads about this, try searching 'flat towing' for more explanation.
I can't speak for your exact truck, but my 1993 Land Cruiser does fine as a flat tow. I bought a tow bar, trimmed down the width of my tow hooks to fit, and it tows great. I hook up the tow bar, put the transfer case in neutral, turn the ignition on and then off to unlock the steering wheel lock, and go.
I have synthetic oil in the transfer case and differentials, but I doubt that makes any difference.
I also added massive safety cables, an auxillary braking system with automatic break away and wireless indicator to know when it is activated, and cheesey magnetic lights for brake and turn indicators. The brake system relies on a twelve volt supply to power an air pump, so I ran a power cable from my
tow vehicle battery. This eliminates the possibility of running down my FJ80 battery.
Jack Nichols, 1993 Land Cruiser (Casper)
If you have an AWD 80 series (as opposed to a part time setup, which I'm not sure about) I would not flat tow.
The t-case will be spinning but will not be lubricated. That'd be considered a "bad" thing.
There are several threads on this, and why not to do it. The owners manual states flat out not to flat tow except for short distances as an emergency.
