Total Chaos Lift
bat country
2 questions:
has anyone gotten the ENTIRE front suspension setup from them yet, and if so how do you like it? if you only got part please let me know what part you got and what other equip you got working around it.
and
this may be just my inexperience asking, but is it possible/practical to combine the TC setup with OME heavy kit? will i lose wheel travel if i do? would a heavy front end (ARB + Winch) sag more without the OME setup and with the TC one?
They don't offer a lift unless you mean their long travel kit which isn't a complete lift as it lacks shocks and springs and it is meant more for desert racing flex(13"wheel travel) than lifting. They make a UCA(upper control arm) that can be used with a lift it may or may not be needed depending on how high you go. I'm currently running the DR 3" lift and did not need to go with a new UCA as I had no alignment issues and the UCA does not contact the coil bucket or coilover.
attachment.php
attachment.php
yeah i had read part of it... the axles were kinda what turned me off... that kit is insanely expensive.... i'm thinkin the OME is prolly the best for my budget atm... perhapst a longtravle kit would be good later on.
