Why? There are plenty of kits out there.
This is probably the most descriptive post I can find on making a set. Hopefully $50 at a junkyard will yield all the parts. Then its just fabwork to make the arms.
Super cheap junkyard swaybar - Pirate4x4.Com Bulletin Board
I'm guessing "if I read that right", there is a keyed steel side and a keyed cast side. You could possibly rob the two steel parts to make your arms.
As for the cast parts, if its toyota it will be cast steel, not iron. Which is perfectly weldable, just like if your welding to an axle housing or knuckle. Some preheat to be safe.
