Torque values - knuckle studs and tie rods
nat
Los Gatos, California
So my manual is nowhere to be found, I was cleaning up and obviously put it somewhere I would easily find it :rolleyes:
I want to finish tightening up my new steering arms and wasn't sure what to torque the nuts on the knuckle studs to. I am also curious how everybody is tightening up their tie rod nuts, run it to a specified value then back it off to get the cotter pin through the castled nut?
Values differ depending on the diameter of the stud..
11mm- 40 - 60 ft#'s
12mm- 62 - 79 ft#'s
What year knuckles do you have?
Pre 1979 were 11mm
1979 and later were 12mm
I snug them up good, no more than 50ft#'s, and DO NOT back the nut off to make it line up...make it line up while it is being tightened....
Ii is for my 72' Piggie, but I have large pattern knuckles.
Thanks for the info :cheers:
