Thanks Retro... we're both getting there.
Not sure what you mean by welded/locked but the 'steer' does appear to be coming from the rear.
Sometimes on built up trail trucks, the owner will weld the rear end. This is a 'poor man's locker'. I.e. the vehicle's rear axle is permanently locked. It means that when turning, the rear wheels rotate the same even though their circular paths are different. It causes the rear to 'scrub' and can result in pushing the front making it difficult to steer.
I don't think this would be your entire issue, but would explain part of it if true.
Does the truck have selectable lockers on it? I.e. the rotary switch to the left of the steering OR ARB? It could still have an aussie locker, which would be OK too.
How to find out...
Park on level ground with the front end chocked and the back end in the air on jack stands with the parking brake off, transmission in park and the transfer case in gear.
Grab the rear tire on one side and turn it. If the opposite wheel turns in the opposite direction, the rear end is not locked.
If it will not turn, double check your wheel chocks on the front then put the transfer case in neutral. Try turning the tire. If the opposite tire now turns in the same direction of travel as the one you are turning, then it is locked.
IMHO YMMV -I'm not a mechanic.
