Torque steer after lift
Jefferson City TN
hey guys,
Searched and found a few good reads on torsion bar adjustment and the appearance of torque steer. But had a few specific questions.
06 cruiser, new suspension running 315’s(35’s)
It wanders a little, but mainly notice torque steer on acceleration and deceleration. It’s so bad I don’t want my wife driving it on trips.
After letting the suspension settle I have found the pass side is taller than the driver side (toyota lean). I’m going to adjust it down to be level with driver side and then get another alignment.
If that doesn’t solve it I’m considering a part time conversion. From what I’ve read that would also solve the issue.
Any suggestions would be great to get it handle closer to “normal”. I know it’s a lifted truck, just don’t want the wife to get in a wreck due to it pulling on acceleration or deceleration.
Thanks,
Tommy
Pretty sure the Toyota lean is supposed to favor the driver's side (to balance the weight of the driver and fuel). Are you using the right term? you really shouldn't feel torque steer at all with a real wheel favored AWD setup, but definitely not on deceleration. Disclaimer: I'm not always sure what I'm talking about with some mechanical things...
No definitive answer to your question, but I'd absolutely be checking my alignment. Get the rake and lean set how you want it (is the front or back leaning?), then get it aligned.
The 315s may be a big part of this too, I'm sure they'll want to tramline more due to the width. If you have access to a spare set of wheels and tires closer to factory spec, maybe throw them on and see how the ride changes. Might help you isolate the problem.
Good luck
100's don't like to be leveled, they need some rake. That might fix your problem. If it wanders at speed (like it feels like your driving in the wind), it might be your caster. If it's that, have your alignment place max out the caster when you get it aligned.
I'm having some wandering and sloppiness, I am getting aftermarket UCAs to get more caster I have heard this can help significantly adding 2-4* of caster.
Lifts don't cause torque steer, they cause bump steer. If your truck is pulling on acceleration, it could be a sticky caliper, bad alignment, or faulty suspension components. Lifting it didn't cause it to pull, but it might have exacerbated the symptoms of an existing deficiency.
Thanks guys,
Spent this morning working on it. I’m currently across country in idaho (from TN) and think I found some of the issue.
A hub measurement from center to fender on pass side turned out to be 24.25 while the driver side(toyota lean) was 22.5
I leveled the truck side to side in the front and it has roughly 1.25” of rake.
That all but corrected the torque steer and removed CV vibes.
I contact the shop that did the initial work and they came clean that this was there 1st 100 series. They had the torsion bars cranked way high.
It’s over at the alignment shop now and I should have a better idea of how it will ride. But Initial drive to the shop was night and day difference.
