torque specs?
Squamish
hey i just installed my ome medium lift and was wondering what the torque specs were for tightening the shocks and the rear sway bar?
From Slee's site re: the shocks:
After all the bushings are installed, the shock nuts can be tightened to speck. This should be done until the bushings start to bulge but do not over tighten.
When tightening the nuts, be sure the washer with the index lip is properly located in the holes. If not, back off the nut and move it until it is properly seated."​
From the '97 FZJ80 FSM:
REMOVE FRONT SHOCK ABSORBER
(a) Jack up and support the axle housing.
(b) Hold the piston rod and remove the upper mounting nut.
Torque: 69 N·m (700 kgf·cm, 51 ft·lbf)
(c) Hold the shock absorber and remove the lower mounting
nut, shock absorber, cushions and retainers.
REMOVE REAR SHOCK ABSORBER
(a) Remove the lower bolt holding the shock absorber from
the rear axle housing.
Torque: 64 N·m (650 kgf·cm, 47 ft·lbf)
(b) Remove the retainer and 2 cushions, disconnect the
shock absorber.
(c) Remove the 2 upper bolts and shock absorber.
Torque: 50 N·m (510 kgf·cm, 37 ft·lbf)
(d) Remove these parts from the shock absorber:
Nut
3 Retainers
2 Cushions
Bracket
REMOVE STABILIZER BAR
(a) Loosen the 2 bolts and nuts.
Torque: 25 N·m (260 kgf·cm, 19 ft·lbf)
HINT:
After stabilizing the suspension, torque the nut.
(b) Remove the nuts and disconnect the stabilizer bar with
the links from the bracket
Torque: 15 N·m (153 kgf·cm, 11 ft·lbf)
HINT:
(c) Remove the 2 bolts, nuts and links from the stabilizer bar.
(d) Remove the 4 bolts and stabilizer bar from the axle housing
with the covers.
Torque: 18 N·m (185 kgf·cm, 13 ft·lbf)
HINT:
After stabilizing the suspension, torque the bolt.
(e) Remove the 2 covers and cushions from the stabilizer bar.
HINT:
Install the cushions and brackets touching the line painted on
the stabilizer bar.​
In typical FSM fashion the "installation" instructions just state that installation is the reverse of removal :D
HTH
