My 1994 FSM has 36ft-lbs for the front differential drain and fill, and doesn't specify for the rear diff or the transfer case.
Also, the first time I did my own differential oil change, after dealer-only service, I found the shaped steel washer on all four diff drain and fill, which match with the 36ft-lbs spec. I see 29ft-lbs used with the copper washers. The transfer case had the flat aluminum washers.
For those reasons I've always gone with:
Front & rear diff, drain and fill: shaped steel washers @ 36ft-lbs 12157-10010
Transfer case: flat aluminum washers @ 27ft-lbs 90430-18008
Funny, my 1996 LX450 manual shows 39 ft-lbs for drain and fill plugs for both differentials.
No mention that I can find of the T-case torque for drain and fill....
