Torque, cylinder head H engine
Northern Norway
Website
www.nlck.no
My H-engine in my HJ45 has been leaking oil from the cylinder head gasket, I have replaced it, but I used the torque spec from the 2H engine. The 2H engine has a lot more cylinderhead bolts than the H engine. I used 113 NM, is that abut right for the H engine ?
Diesel tech
Hi Steinar,
I don't actually know the answer to your question, sorry. However, the guys on the Diesel tech section ( Diesel Tech and 24 volts Systems - IH8MUD Forums ) will definitely be able to tell you.
Also, here is a very useful link for Toyota reference documents:
Downloads Index - Page: 1
I couldn't find a manual specific to the H though unfortunately.
Good luck,
Matt
For the H motor, the Ellery's manual I have states between 125 to 139 nM. The bolts should be done up in a certain order too, I've got the diagram but no scanner.:doh:
