Torque Converter Problem??
W. PA
My rig is 442K miles young, original engine (3FE)/transmission. Runs like a champ.
Lately, when I idle in reverse, it lugs hard and the RPM's drop to about 300. In Lo range, reverse idle is an instant kill. Idles in forward fine Lo or Hi. If I keep my foot on the gas to keep the 'idle' about 600 or so, everything behaves exactly as it should. No odd noises or shakes. ATF has always been kept clean and normal, fluid smells normal. Does this sound like a torque converter issue? Other ideas??
Thanks.
Sounds like what I was messing with for a bit. after I checked everything I found a small tear in the intake tube. patched in a cheapy chrome intake tube piece from Oreillys and problem was solved
I definitely have a duct-taped tube, but would that only break vacuum in reverse?
Worth a try. I'll let you know.
KaChing - We have a Winner! Duct tape fixes everything.
On my '97 LX450, the check engine light would come on to let me know I had a vacuum leak.
