- Thread starter
- #21
Thanks! I will probably need to reclock them when I add the weight of a bumper I ordered. You've encouraged me to take a swing at grinding the parts apart. I agree with you on the gussets, I ordered a set yesterday. I can use them either way I end up going. Supposedly the LC100 arms have the first horizontal hole for the gusset pre drilled that the LX470 arms don't have, so that's what I'll look for from the parters if I go that way.unless you need to re do bushings or re clock the torsions leave it alone. i hou absolutely have to split it, using a die grinder isnt going to weaken anything to remove them, id use the OME gussets when you put it back together
