Tool List? Front Discs and Belts
I'll be searching through two different PMs I hope to get done this week.
But I know some of you guys know this truck like the back of your hand.
Anybody know a quick list of all tools required?
(I may be working on it tomorrow, no parts/tool stores to be had then)
Gracias
From IdahoDoug's post (Changing belts in 25 minutes) it looks like you only need basic 12mm and 14mm wrenches and sockets.
From my own experience working on the front axle, there are a few things you will need above and beyond standard wrenches/sockets. 54mm socket, torque wrench, 20lb fish scale, brass drift & hammer and snap-ring pliers. An impact gun might make removing the rotor bolts from the hub easier and if you plan on removing/repacking the hub bearings a seal puller will save your knuckles. An FSM is always nice too. If you don't have replacement gaskets, be careful pulling the drive flange off the hub so you don't tear the fibre gasket between the two. I also bought a few extra "tabbed lock washers" (the thing that goes between the two 54mm nuts) because I normally wreck them.
HTH!
