Too Small Wire?
Humboldt Nation
Sorry about the bad pic. Guess I'm having technical problems right now.
This is the recepticle for the Norcold fridge plug from my aux. battery. The Norcold side is fine as is the positive wire and connection but there's a break in the connection in the burnt part of the ground wire pictured here. The plastic loom and outer electrical tape both melted. Never did smell anything and the fridge worked fine up till the other day on a trip. Of course, that was 2 days after a run on the McGrew Trail with TLCA.
I guess my ground or both wires are too small?
thanks
:cool:
That looks like a connector failure to me, Russ. Either a bad crimp on the wire, or not enough spring force where the female part of the connector meets the male. Either would cause higher resistance than normal, which would lead to overheating. Lucky you didn't have a fire.
At a minimum, you need to replace the connectors and the receptacle. Also, make sure the receptacle is rated for 15 amps and is of good quality. I like the ones made by Sealink available at West Marine, but there are several other brands of quality receptacles available. Lastly, make sure your +12v supply wire is fused somewhere near the battery and that the size of the fuse is appropriate for the wire size. The fuse might not have blown in this situation if the circuit wasn't drawing more current that the fuse is rated for, but a properly fused auxiliary circuit is an absolute must for fire safety.
Second thought: In the photo do you see how the black ground wire looks to be about 1/4" shorter than the red +12v wire? If this caused the ground connector to not be in full contact with the male half of the receptacle connector, then you may not have had enough metal-to-metal contact for the current load you were drawing and this caused the connector to overheat. Same fix as I described above: new connectors and a new receptacle.
Thanks. I'll check all that.
The wire size is10 ga. and the fuse is 30A. A bit to much on the fuse I guess. Not quite sure how I arrived at that size.
:cool:
:cool:
I think 10ga and 30 amp is fine, I was looking up that stuff yesterday. As a matter of fact I think you can use 12ga copper for 30 amps. Thats just from the research I did yesterday, people may have different opinions.
There might be an issue with the small section of what looks like 16 or 18 ga. wire.
Keep in mind wire size, current and wire length when doing an installation.
Let's see if this will work. The charts are fairly simple, select your circuit voltage (14v unless you have a 24v diesel), then your wire length and go out to where it intersects the amperage you plan to run. For the above installation: Use the continuous flow chart 14v, 15' (for easy routing), 30A = 8ga wire is recommended since the recommendation is slightly beyond 10ga.
Intermittent current flow chart
Continuous current flow chart
Print 'em or save 'em and keep 'em handy for quick reference.
If you're interested in the additional data that goes with the above charts follow this link: AC 43.13-1B Ch. 11
30 amps will protect 10 gauge wire just fine. A Norcold only draws 2.7 amps maximum. Also fine. I think something else went wrong-a short perhaps? Did you plug in something other than the fridge?
Maybe it's just the picture but that does not look like 10 guage wire. It looks more like 16 ga or smaller. Hard to tell though.
edit--IBCRUZN had the same thought at the same time about the wire gauge. A wire that is too small for the load, like an 18 gauge wire could easily cause this problem.
I could never find a cig adapter recepticle rated over 15 amps. I used a trolling motor connector instead, rated at 40 amps. You may want to swap out the recepticle and plug.
From what's been burned away, it's likely a combination of the plug and connectors, not the wiring.
Thats funny I just grabbed my 43.13-1B/2A
It's never let me down.
Sho nuff 30A too big for that run on 10 ga.
( cool stuff)
DC Voltage Turn-Lock Plugs and Receptacle
Plug with Wire Entry
Receptacle
A unique locking configuration provides a secure connection and prevents attachment to AC connectors. All are rated for voltages up to 48 VDC and current up to 30 amps. Housing is glass-filled nylon.
Plugs have an O-ring that seals out moisture when connected to a receptacle. Blades are nickel-plated brass. Plug with wire entry has three entry holes for up to 8 AWG wires. Plug with cord entry has a single entry hole for 1/4" to 1/2" dia. cord. Receptacle fits into a 1 1/8" dia. mounting hole and accepts two or three wires up to 8 AWG. It has corrosion-resistant electrical components and a water-tight cap. Contacts are nickel-plated brass.
Each
2671K11 $18.80
Plug with Cord Entry
2671K13 18.80
Receptacle
2671K15 22.38
ken
Didn't plug anything but the fridge in. The positive wire is 10ga. I thought the neg was too but I'll have to check on that one.
Sounds like smaller fuse(20A), new stouter power outlet and new connectors properly installed.
Thanks,
:cool:
I hear ya. I still have a copy in my tool box because you never know when it'll come in handy.
