to convert or not?
Nashville, TN
I am starting my research for an engine swap if and when the one goes in , 91. I saw the write-up on the diesel that proffits did, i defaintley dont plan any insane wheeling or need huge amounts of power (im in a 3fe state of mind), but if i will be changing it out it makes sense to spend the money improving.
thanks for all advice
I have been thinking about doing the samae thing myself after driving some diesel power cruiser. If you can do the swap yourself, I think it is worth it. The front clip of a HDJ80 itself will run around $8000 so you can do a direct swap and forget about looking for parts to make the conversion.
There's no way anyone can justify an engine swap of any kind for economy. If it's power you want, or the novelty of a diesel, and a serious project, go for it. You will never recoup the cost in fuel savings, even comparing rebuilding a blown motor to putting in something other than stock.
-Spike
Then you can either spend $5-10K putting in a diesel, or less than $2K to rebuild the 3fe, which is a great motor. What are you trying to accomplish?
-Spike
sseaman,
I have a friend that has a few toyota diesel on slow boat right now. Should be here in a month if I remember correctly. Let me know if you want somemore details
