[TN] FJ 60/62 Old Man Emu leaf springs and suspension parts
Memphis, TN
I am selling a set (4) Old Man Emu leaf springs. These are the original OME springs, made in Australia. They came off a junked FJ60 so I do not know how many miles are on them or if they are heavy or light duty springs. One of them still has a code that you can see and it says OME 2210 if that means anything. The fronts have 5 leafs and rear have 8 leafs. They come with greasable frame pins. I am also including a pair of extended shackles with greasable pins, a pair of rear Alcan add a leafs ( add about 1" of lift), aluminum castor plates, 2 OME rear shocks, 1OME front shock (it is missing the bottom bushings). I am asking $450 for everything ( not willing to separate) and I would prefer local pick up or mud ship, might consider shipping but I will not have time to do that for about 2 weeks. Located in Memphis, TN
hmmm.... how much lift would this add if any?
It is hard to say how much lift they will give you because the truck they came off already had the axles removed. I would not expect greater than 2.5" (that is the original ad said) unless you added the add a leaf or used the extended shackles, but I have heard that the original OME springs seem to hold up better then new ones. I wish I could give you an exact number.
Next in line if your other shipping deal falls through.
