TLC Paint Jobs
Portland, OR USA
I just recently bought a 95 TLC. The first thing about the car that I noticed when I pulled up to the PO house was how good the paint job was. Do TLC's have better paint than a 4 Runner for example? Also, I was talking with my dad and we were trying to figure out what exactly makes a TLC so much more expensive (new) than all the other models?
Thanks for all the good threads on the site!!! :cheers:
I'm the second owner of my 97, and the paint on it is also in almost new condition. I think many of them have been pampered and garaged by previous owners.
Most of the ones I've personally seen that clear coat flaking or faded hoods have been outdoors a bunch in the sunbelt.
I agree with the drivetrain comment earlier.
Welcome!
Welcome!
It's not just the drivetrain. 80s are built like tanks - there are good and bad things about that (platform strength and durability vs. weight).
Half an hour behind the wheel should awnser your question :D
20 Minutes behind the wheel and there is no doubt that it is a quality rig. I was just wondering if anyone had any facts on why there was an extra expense. I saw someone mentioned the drivetrain, what about the drivetrain is better than a normal toyota? Sorry, I am a pretty good maintenance mechanic as far as all the fluids and grease ect, but not good at things such as axles ect. Are the axles beefier than normal? Frame stronger? ect?
yes and yes:D
Take any mechanical section of your truck apart and look at it. Compare its overall size to the same component on a mini-truck or 4Runner. The 80 series birfields are like 30% larger than the mini-truck birfs. And the 86+ IFS? those axles look like swizzle sticks compared to the 80's axles. It's comparable in strength to a Dana 60 or even more.
Everything on the 80 is HUGE. It's big and relatively simple. They're designed to run in areas with poor maintainence support, like Africa. They're designed to be run (and abused) as fleet vehicles, by tough customers such the UN and Red Cross. They are also basically military-grade trucks, designed to be used as ambulances, gun platforms, mobile comm hubs, and troop carriers.
Take an already heavy-duty drivetrain which infuses simplicity with the cutting-edge of available computer technology, then add the creature comforts demanded by the spoiled North American market, and you can see why the costs of manufacture climb.
It's not just the cost of manufacture, it's the cost of importing. It's a J VIN, made in Japan, compared to made in CA. or Texas or the other US plants Toyota has. It's expensive to import cars, that's why all the Japanese car manufactures have plants in the US.
First, the LC chassis is virtually built like a tractor, using a lot more steel than other truck lines. It is much more solid and that costs money. Steel is cheap, that's why we make soup cans out of it. But to precisely machine or weld it takes a lot of care, more so if you use it in quantity. Also, a heavy chassis costs more to transport than a general-duty like a 4-Runner or T-100 type.
Second, the 80 series body was custom built by a subsiderary department of Toyota. When I did major work on mine I found a lot of custom bodywork from the factory. Portions of the roof, quarter panels and front fenders were hand-formed at the factory by skilled artists. The fenderwells are steel, not plastic skirts. The 80 body is of the highest custom quality that has ever been built in any quantity in the auto industry. It is not a collection of spot-welded tin. If you know bodywork it is apparent that this is an exceptionally well-built truck that has no peer in the market. That does not come cheap. You own the best, enjoy it!
