TJM Lockers
LA, CA
There was a thread with a different topic that went this way earlier, but I thought I'd give it it's own thread this time:
Does anyone know if anybody is carrying the TJM locker for the 80 series in the US? The main draw for me is the elimination of the rubber o-rings used in the ARBs, so no more oil in the air line.
TJM advertises it here:
http://www.tjm.com.au/Default.aspx?tabid=93
Selling points:
1. Rubber O-Rings (which are prone to wearing out) are not used . This means that there is no chance of oil being pumped back up the air line due to faulty seals.
2. Thicker materials and a stronger carrier are used in this assembly.
3. Solid one piece cross shaft with hardened thrust washers.
4. Larger planetary gears compared to other standard pneumatic diff locks.
5. Larger bolts to hold carrier together, Note - All bolts can be torqued up.
6. A reinforced rubber external hose extension is supplied as standard to reduce chances of possible hose breakage.
Also, if any of our Aussie or other international friends have any experience with the TJM lockers, please do chime in!
bump.
the pro-locker was origanly designed by the aussie range rover and diff guru jac macmarra, with over 50 years experience. TJM bought the rights off him, i will definatly be buying one. will be a good comparison, i have an arb in the front, and will be putting the tjm in the rear. here is a link to his web site for a bit of background info.
When I first started seeing ads in Australian 4wd Monthly, I emailed TJM USA twice and never got any response back.
