TJM coil spring help
Upstate NY
Is anyone out there running TJM springs? I am looking for some actual before and after measurements so I can decide on spacers and shocks. I bought fronts and rears from the Slee special, but no one is sure how much lift I will actually get. I was told they are rated 40mm and I have 30mm spacers, which adds up to appx. 2.5". I have the yellow castor bushings and want to make sure this will all work together. I can do the math on the proposed numbers, but does anyone have actual experience with these?
Thanks,
Ken
Sorry, I can't help here, but if you email TJM asking the spring free height, spring rate and wire diameter, many people here will be able to tell you based on a comparision with OME.
Moreover, a friend told me he had seen TJM suspension in UN HZJ105 service cars, so that's a good sign I believe.
I've got the TJM XGS springs, shocks & castor bushes on my 95 I would say it was more like 50mm lift.
I didn't measure before but my old stock springs were like a low rider in comparison.
I'll post up some measurements this weekend (I'm just about to finish a nightshift & need to go sleep first!)
One thing I will say about the TJM suspension, the ride is very good.
Cristo said they were listed as 40mm but thought they might actually be more than that. They only had TJM front shocks to go with this so I had to order Nitrochargers for the rear. These are the standards, not the L's.
Did anyone else buy these on the Slee deal? $200 for all 4 springs, seems like someone must have grabbed them to try.
Apologies for the delay.
Right, the measurement from ground to the lower edge of the center of the wheel arch is 38 inches.
This is the same front & rear.
For comparison, this is on my truck running 285/75/R16 Cooper SST's with no load & no winch bumper.
Brett,
Thanks. I took some measurements Friday, and with 285/75-16 BFG's and Arb bumper (no winch) I had 34" front and 35-7/8" rear, so given the 200k miles on my stock springs I'm thinking maybe 2" lift without spacers, although I will be running 2-3 hundred pounds in the rear with my floorbox and tools. I think the 30mm spacers are too much for my yellow bushings. Anyone have any input on this?
Max,
For how long it would take to fit the spacers I would be tempted to try the springs without spacers first. the springs are designed to carry load.
You could always fit spacers later if needed.
With regard to the bushes, did you get the TJM castor bushes? If you did, they work really well.
Yes, fitting the springs first is exactly what I'm going to do. After that I'll measure to see where I'm at. I did get the TJM yellows, but traded them and my bars for a set that already had the OME yellows pressed in. Was that a bad move?
OME specs here:
https://forum.ih8mud.com/80-series-tech/42788-ome-coil-spring-specks.html
I picked up a set of the TJM springs as well. I emailed them directly about spring rate and here was their reply. I measured my springs but don't remember how tall they were. It is as easy as taking a tape measure to your springs.....
Dan;
770FR80B rate: 240 lbf/in
770RR80B rate: 200 lbf/in
I hope this helps you .....
Brad Cooper
Customer Service
ph: (07) 3865 9999
Fax: (07) 3865 3977
brad.cooper@tjm.com.au
cid:image001.jpg@01CA63AF.9089D860
Not sure what that means exactly. Please explain?
Linear springs have three basic variables. Wire diameter, free height, and spring rate.
The spring rate is how many pounds will compress the spring one inch. So, for a particular spring, 200lbs will compress it one inch, 400lbs will compress it 2 inches etc.....
The Part numbers above coincide with the part numbers that were on your TJM boxes. FR=front, RR=rear.
Measure your free height and wire diameter and then compare with the linked OME spring specs to see how your springs stack up to the OME. IIRC, they are comparable to the heavies, but the spring rate on the rears is a bit lower....
No I'm sure you'll be fine. I wouldn't thimk there is much difference between the two.
Also, FWIW, most of the research that I have done indicates that Both ARB (OME) and TJM springs are made by King springs to the vendor's specs.....
OK, springs and shocks are on. Center of hub to flareless fenders is:
22-3/4" front (ARB bumper, no winch)
24 rear (no second or third row seats, factory rear bumper, no spare.
Based on some numbers I dug up for stock springs I think I picked up 2-3/4" to 3" on the front and 3'" to 3-1/2" on the rear.
Total overall gain from start of swap from ground to fender is 4" front and 4-1/8" rear, including a swap from 285's to 295's.
These measurements are springs and shocks only, no spacers. Haven't been offroad yet, but onroad ride is very nice, even with no weight in the back.
