Tires?
lift or 33x9.5's.
some extended shackles will prolly chear 33x12.5's. I have 32's under mine stock, they fit OK......
32's under the stock suspension, but as you will notice the rear fenders are not stock anymore :(
yep Gig Harbor......born and raised :)
It also depends on your backspacing, but either way, they will rub a little in the front of your fender when turning under articulation. In my opinion, a 3" backspaced rim would be perfect. A 3.5" BS brings it a little close to steering. I am running 33" tsl on 2.5" BS rims on a stock, sagging pig. But I also busted out the saw on the front. The only rubbing I had before a 1" body lift was the largest side lugs. With a 33x9.5or 10.5" tire you should be fine. With a mild tire like an all terrain, you may be able to get away with not clipping the bottom of the front fenders. However, they are easy to trim cleanly and I even think they look better angled than the stock completely horizontal look. But if your fenders have no rust, which I doubt, you should probably leave them alone.
