tires? Wheels 17s ????
Northfield, New Jersey 08225
Have a ome meduim lift. The stock rims are kinda beat up so i scored some 17s from a 03 Seqouia. Heres my question. My original tire upgrade was going to be a 285 75 16. Now that I have the 17s have my options changed? The reason I ask is I went to a discounttire and at 285-75-17 there was only 2 tires options where at the same number but in 16 there werr 24 choices. Do I need to put a different number in with the 17 inch rims. Thanks folks. Look foward to hearing from you.:o
On a side note I am going to get my stock rims sandblasted and powdercoated so I will let you guys know when Im done with the process.
The wheel size will change the overall tire size if you use the same numbers. A 285/75-16 means the tire is 285 milimeters wide, and the sidewall is 75% of 285mm, or about 214mm. The total tire height is 2 sidewalls plus the wheel, or 214mm+214mm+17 inches (nice how they mix metric and SAE, huh?). So the 285/75-17 is an inch taller than the 285/75-16, at least in theory since very few tires actually measure correctly. The tire store should be able to point you to some tires that are the size you want.
thanks spike. Spoke with another mud menber and said to change the 75 to a 70. Tire went up in price too anywhere from 45 to 100 bucks more. OUCH
The size your looking for is a 33" diameter tire. Thats right, 285/70R17 is a 33". Or you can go 33-12.50R17 which is a bit wider and runs about 32.6" depending on the manufacturer. OR you can go 35" like you really want and run 315/70R17.
Every time you go up a rim size, it seems the tires get more $$. Good thing you arent running 18's!
