tires size
i have 35'' tires but no 35'' spare could i use my old 33 as a spare with the 35
Briefly maybe, in low a traction situation.
Punctuation.
Punctuation.
Yep, something has to give, or something will probably break. When I bought my 92 truck, it had a "thump" or like a weird hesitation in 4wd. The PO said it needed a new CV shaft, and since I didn't know much about them, I believed him. It didn't take long for the front end to basically seize up. Turns out he broke the original rear end and replaced it with a different one. The factory had 4.56, and he put in a 4.30 rear. The hesitation/ thumping was the drive train binding up due to turning at different speeds. It sheared off about 4 teeth on the 4.56 ring gear. Coincidentally, 4.30 to 4.56 is about the same difference as 33s to 35s.
