- Thread starter
- #21
Thought I would report that the speedo readings on my LC200 seem to have ADJUSTED for the tire size change.
By installing tires that are 1.6 inches larger in overall diameter, my tire sizing calculator (see first post in this thread for link) indicates that my indicated speed should be 3.6% lower than actual. So, with the larger tires, when the speedo indicates 60mph the vehicle is actually traveling 62.2mph on the math formula.
Now here is the cool part, using my hand held GPS I just tested the speedo gap and there is none! This means one of three things: (1) the speedo is somehow linked to the GPS or (2) the speedo is linked to a system that compensates for the tire size or (3) the speedo is marking off the tire pressure monitors which are mounted to the wheels which are the same size. If (3) is the answer, then speed would vary with wheel size deviations from standard. I doubt this is the case since non-US LC200s don't have 18 inch wheels as standard.
Either way, pretty cool. I tested speeds ranging from 30-80mph for a 10 mile ride so I am confident my results are accurate.
So Toyota can't install a tire pressure monitoring system that tells you which tire is actually low and they put their towing electrical hook-up in the same spot Homer Simpson would install it, but the speedo is set up somehow to adjust for tire size. Pretty cool.
Yeah, you may be thinking I have too much time on my hands, but any excuse to tinker in the garage during Thanksgiving is a welcome break. I do have a beer fridge in there.
