Tire sizes
Chelsea, AL
After doing a good bit of research I finally decided to go with Nitto ridge grapplers. I couldn’t find a clear answer as to what the largest size I could go with and not rub.. my initial plan came from a thread I read on here where someone went with 305 55 20’s but they required wheel spacers.. he went with 1” and then later mention that they weren’t quiet big enough to clear the factory studs.. then I read where 1.25 were the perfect size for the 200 series. So now.. I read all about the pros and cons to wheel spacers.. and finally decide it’s not worth it to me for just the “look” So I find a site that gives the exact measurements of tire sizes I see that it’s very likely a 305 50 20 will fit with no issues! (Less than a full inch wider and less then a full inch taller than stock) However I can’t seem to find that size in any of the tires that I was interested in.. that’s when I came across the grapplers! It’s more aggressive than I was going for because I didn’t want the noise.. however after reading A LOT of reviews, everyone said it was quiet! So I pulled the trigger and I couldn’t be happier with them! Did
not require mud flap delete or any modification what so ever!
