Tire size ?s
Paso Robles, CA
Would I be able to tuck 33x12.5s on my stock 15" wheels and stock suspension? Or is there not enough fender clearance? If there are any owners who have already done this out there, what is your clearance like? How is your turning radius affected? Any rubbing when you have the wheel cranked?
On a side note, I searched for a thread like this, and the only search result I could find was a thread involving my same question, but for the 60 series. And in that thread, it was divided between "yes, it will work fine" and "no, you'll get serious rubbing".
You should be able to fit them with some minor rubbing. You won't have much flex however.
Part of it will depend on how badly your stock suspension is sagging as well.
By flex, do you mean suspension travel? I'm not planning on wheeling the daylights out of this thing so I am not sure how much of an issue that would be.
Also, how can you tell if your suspension is sagging? There looks to be plenty of room between the tire and the fender well with the 31x10.5s on there. I'm assuming things like age, fatigue etc would be determinants in how much it's sagging.:confused:
