Tire size question - LX570
SOCAL
Hi,
I am about time to replace new tires. The LX570 is currently sit on 285/65R18, AHC lift.
I am thinking to go with 295/70R18. Was there going to be a lot of work prevent rubbing? Also, would the spare tire fit ok?
I appreciate your input in advanced.
Thanks.
AW
While I have not done the sensor lift yet, I just mounted up some Rock Warriors with 295/70/17 that are slightly larger. I have some rubbing and will need to trim the splash guard here. While your tire size isn't that tall or wide, you should be OK! I was running a 275/65/18 that had minimal if any rubbing. You may have some rubbing...
i have run 33's on a few lx570's. if you can get 21" hub to fender on the front you ll be fine. I removed the front mudflap and did the mod to move the front inner fender forward no cutting.
LX's handle big tires with little effort. What wheels/wheel offset are you running?
Rub points that need addressing are at the 3 o'clock and 9 o'clock positions. Here's the basics of what you need to do.
