Tire size decision?
Austin, Tx
Well I searched but apparently wasn't searching the right key word. I am selling my almost new 315's to my buddy and I am going to buy some super swampers. I really wanted Iroks but they jump from 37's to 39.5. I want larger than 37s. What do I need to make 38s-39.5s fit? I don't mean fit and drive down the road. I wheel the s*** out of this. I will have 5" comp springs and possibly 2" coil spacers up front to level it out. I want to be able to no rub under normal driving and would prefer little to no rubbing while offroading. Are wheel spacers neccessary?
D
Ok, well that answers part of the question. How big of a spacer? 2"? And what about the rest of the questions?
D
I was afraid someone would say that. I don't want to cut it up yet. Next year I may truggy it, but as of now I don't wanna go hacking the fenders and inner fenders out. I am torn between Boggers, TSL's or Iroks. The thing is the Iroks come in 39.5X13.50 or 37x14. The Boggers are either 37x13, 38.5x11, or 38.5x15. The TSLs come in 38X13. I would prefer Iroks, but don't want to hinder myself with their size. Who on here runs something bigger than 37s besides Slee and that one guy with the gray 80 on 40" Nittos?
D
Plenty of people have been running those 38.5" michelins (XML's) that are 11" wide on your lift height.
Go skinny boggers on 1" spacers and ensure the suspension travel is spaced down so you only have about 4" of up travel. Don't use extra long rear shocks that angle the tire so much into the wheel wells at full flex.
You shouldn't have to hack it up if you tune the suspension properly, but if you go anything but a skinny tire I think you'll have little choice.
You should run 37's until you go truggy, you'll need new axles at that point anyway and you could go to 5 on 5.5 to really open up your rim options. No reason to go extreme on tires on the stock junk.
I'm running 37 x 13.5 IROK radials in combination with a Slee 6" lift and 1 inch body lift. I'm running 15" beadlocks with spacers to achieve the 3" BS that Creeper mentioned. I have had to modify the inner wheel well slightly to prevent rubbing.
I doubt you will be able to run 40" tires on a 5" lift without modifying the wheel wells. Not unless you want to limit your turning radius and add large bumpstop spacers. Width of the tire will be a limiting factor as much as height.
Break out the sawzall. If you really are wheeling the hell out of this rig to the point you need 40" tires; what is the hesitation?
What terrain to you ride in most of the time? Have you ruled out the LTB? It does almost as good as the bogger in mud and does well on everything else. They're a little loud, but not as loud as the bogger.
Rocks. Trees. More rocks. No mud. Well I try and avoid mud.
Break out the sawzall. If you really are wheeling the **** out of this rig to the point you need 40" tires; what is the hesitation?
Because I drive it everyday. It already has several dents, but I am just not to the point of wanting to cut the fenders. Having another truck on 44" boggers and rockwells I am quite familiar with the trusty sawzall. I have no objection with taking a sledge hammer and pouding in the inner fender wells if need be. Just no cutting...yet. If I can't clear the 39.5x13.50 Iroks then I guess I will go with the 38"x13 TSL's. I really don't want Boggers due to the treadlife, and their crappy performance on rock, they also chunk horribly on rocks.
I don't have any bumpstop spacers as of now, and I have yet to rub once while offroad. I know with bigger tires I might. Currently I have 5" comps, in the front, and J's in the rear. I will buy a set of 2" spacers for the front, and put my 5" comps in the rear, but I would need alot more castor correction than I currently have to run the spacers. I already have longfields in the front, and I going to get some poly's for the rear so I don't think I should break too much. Eventually I will put rockwells under it and be done. But thats a year or so away.
So the concensus is I can run the 38" TSL, or 38.5" x 11 Bogger? Not the 38.5 by 15?
D
D
Consensus should be that a 37 is the biggest tire you can fit without some degree of other work (at normal lift heights).
Of course, a lot of rubbing depends on how much pure articulation you are achieving in rock crawling. If you have never once rubbed a 37" tire, and you have no wheel spacers and no trimming, then you aren't fully stuffing that 37 or even coming all that close.
Which may mean that 38's won't be that much of a stretch. But the 80 can fit a bigger skinny tire more easily than a somewhat smaller and wide tire, so skinny makes sense for what you are trying to do.
Buy the tire you want - the rest will come easy.
Well, I really want a 38" Irok. :) But there is no such beast....I don't like the plain look of TSLs, I have had them before. I have never had Iroks. I guess I could just buy 37" Iroks. I would like to see a pic of a truck with 315's and one with 37's. Anyone know where I can find one?
I want more ground clearance, and a meaner profile than what my truck has now. I hate to lift it much more as it already feels like I am wheeling a school bus.
D
Run the 39.5" Irok! Isn't that what you really want to do anyway? Wheel spacers, some possible trimming and bumpstop spacing will come into play, but not too much if you tune it just right. I have been comtemplating the the same tire, but I went the trimming route on lower lift. You already have 5.29's, so go for it man!
Keep in mind that the 37" irok is actually smaller in size than the 36" irok.
The 36 (which is what I run) measures 36.8" tall
and the 37 measures 36.5" tall.
also, the tread width of the 36 is wider than the 37 even though the sizing is .5" wider. (11.0 vs. 10.7)
Wait... I just realized that you might be running 16" wheels.
If thats the case, then the 37 is only 0.1" taller than the 36, but still has a skinnier tread pattern than the 36.
WTF? That is weird?
D
