Tire Question
Ogden, Utah
I just a quick thread, and not to beat a dead horse but, MY question is will a 33x12.50x15 fit on my stock 92' 15x7 rims or will I need to upgrade rims. I thought I saw a post with a 35" tire on a 15x7 rims. Any thoughts or inputs?
What tires? I would go to the manufacturer's site and look at the specs for that size and the "recommended" rim/wheel size.
According to tirerack.com a BFG MT 33x12.5x15 should be mounted on a rim/wheel of 8.5-11" in width. The 33x10.5x15 BFG MT will fit on a 7-9" rim
My initial thought is that no, you should not mount that wide of a tire on a 7" rim but I've never actually done it so no real world experience. I imagine that if you go ahead and do it anyway tire life will be less than exceptional.
Thanks Cosair, that sums everything up. Just what I was thinking as far as type of tires. 33x10.50x15 is the best option in tire size for me, without purchasing new rims.
You can mount a 12.50 tire on a 7" wide rim. Is it ideal? No, but it can be done and you'd be fine even for wheeling and airing down. Now, the trade off to that is that your sidewall of the tire will bulge out more, and you won't be able to air down as far as if you had them on, say, an 8" wide rim. I ran 35x12.50s on a 15x7" rim for months of hard wheeling on my old Xterra, and never had a single problem with it.
The manufacturer's specs are a "cover their own ass" thing in case something happens to you with that setup...but those recommendations are not a bible to follow when talking about tires and wheels.
If you want to stick with your stock Yota rims and put a 12.50" wide tire on them, you'd be fine...you may rub a little while turning as the offset and such is not ideal for that wide a tire...but you should be OK.
dcFJ, thanks I was writing this to find out what you had said. I am thinking of that size for future upgrade in rims, but for now it will be tires then rims. So, it is fair to say that I will be alright with a
33x12.50x15 BFG A/T's on a stock rim, until I can afford new rims. Thanks and any other input is welcomed. John
I've got a similar tire question-I'm picking up my new-to-me 96 fzj80 on Friday from CruiserSolutions with the stock 275-70-16's-my question is since I've yet to lift it(which will be OME medium 2" to come) what is the max tire I could stray from w/o spacers? Don't seem to be many tread options in the stock sizes but I'd like to think I could get away w/ 285's. Anyone got feedback on if that's a bad idea until I lift her....and pics will be forth coming....96 Locked..Arb bull bar..no winch yet..anyone got a Kaymar for the rear they want to part with?????
...since I've yet to lift it(which will be OME medium 2" to come) what is the max tire I could stray from w/o spacers? Don't seem to be many tread options in the stock sizes but I'd like to think I could get away w/ 285's. Anyone got feedback on if that's a bad idea until I lift her....
Powdahbonz,
There are a lot of threads out there that discuss this issue, including a section in the 80 series FAQs. If you haven't yet found the FAQs I highly recommend you read through them, if for no other reason than to familiarize yourself with them and see what is in there:
https://forum.ih8mud.com/showthread.php?t=84888
That aside, yes you can go up to 285s without the lift. Did that for about 6 months on my LX with no problems although I never went off road during that time. I've seen folks go up to 315s but that almost always results in rubbing, even when just driving on the road.
For more info I'd recommend reading this from the FAQs:
https://forum.ih8mud.com/showthread.php?t=114057
