what would the reccomended cold tire PSI be for a Michelin Defender LTX M/S 285/R60/18 be for a LC? just realized these may not be stock so my 33psi may be underinflated?
Thanks!
Edit: research says i should be at 50 psi MAX, am i that off?
Thanks!
You're not giving me a lot of info, so I'm forced to make some assumptions. If any of these assumptions are incorrect, then the tire pressure recommendation I'm about to give may be wrong - so correct me if I'm wrong:
You are asking about 285/60R18/XL 120H Michelin Defender LTX M/S tires, correct?
You are mounting them on a LC200 and NOT an LX570, correct?
If both these assumptions are correct, then the RCTIP (Recommended Cold Tire Inflation Pressure) for those 285/60R18/XL 120H tires on your LC200 is 33psi F/R.
how do i tell if it is an XL? sorry i dont know much about this stuff. I went outside and looked at the writing on the tire and what i posted above is what it said.
Thanks!
Ride is great. Does great in the snow and ice. I have no complaints, BUT, i came from an 06 saturn ion so you can imagine the difference in both vehicles. 5 stars out of 5 haha..
