tire pressure
On some smooth black top, take a piece of chalk and run a line across the tread. Roll forward <100ft, checking every rotation for where the chalk is rubbing off. If it wears off even, then you're tire pressure is right for great wear; if the center wears first, then you have too much air; if the edges wear first, too little air.
Yep, should work with all tires on all vehicles.
Try that technique with TRXUS. You'll be at 15 PSI (maybe lower than that) before you get the outers 1/2" of the outer lugs to touch flat pavement. Tire is designed to run on the center 10" of tread (on a 12.5" width) at road pressures, increasing contact at aired down offroad pressures. It's not a "flat" tread section like MTR or Toyo MT.
I run at 30-31 PSI for optimal ride and handling.
You're right, but the Trxus' profile is pretty obviously not flat, but I guess that should be noted. Also should be similar on the Iroks, outer 1/2" or so wont touch, but the majority of the tread should touch, you can judge by that.
Interco is probably something of a class in itself anyway...you run those babies however they demand to be run :D
At least for trxus, I can't run them over 35 psi or they handle like crap, and too low and they get "boggy" and loud. You don't have to ask about PSI...they tell you...
They should come with balance beads in the price.
Having said that, at the right pressure I think trxus are a better street tire than BFG AT's because you can run 30 PSI and they handle well and ride soft. BFG's need more pressure to run well because the sidewalls are a bit squishy otherwise, and then they get a bit of brick to 'em at higher PSI.
Any time I see these pressures at or near 40 PSI I'm glad I run the tires I do, because that much air in a heavy tire is not going to soak up the bumps for sure. I still remember the day I switched from 33x10.5 BFG AT ko's to 34x12.5 trxus on my old XJ, expecting a major decrease in road comfort, only to be shocked at how much better they soaked up the bumps around town and wondering why I had waited all those years to just go MT because I was scared of the road behavior.
Had the exact same experience with my 80 going from 285 BFG's to 33x12.5 and then 35x12.5 trxus. I just wish Interco would outsource actual tire production so the damn things would keep better balance.
As I've said, I had my parents and their luggage plus four kids in the truck over Christmas (8 people and gear), and my mother, who drives a Lexus sedan, comments out of the blue how nice the Cruiser is riding at 65 mph on a less than smooth highway. Not bad on a 3" lift and 35" MT's :D
