Tire Pressure Warning Light ON!
Los Osos,CA
My parents have a 200 series that they just got. The TPMS light is stuck on and won't go away.
They checked the spare and it is fine.
They tried clearing it by holding the button with the ignition off and the key turned to accessory.
The only thing was that it was missing a valve stem cap, but they put another one on.
At this point it looks like they are going to have to take it to the dealership to have it cleared unless someone has a trick.
Thanks
Thanks
I have never had that problem with my 10k on my 200....dealership sounds like the right idea!
they didn't by chance install aftermarket wheels before they left the dealer did they?
and by hold the button you mean the one at the bottom of the dash down by their feet not up on the steering wheel, yes.
just checking the obvious.
They got it fixed. Apparently the rear tire wasn't "registered" with the system.:confused: I think that is what my mom was told. Anyways, they got it all fixed.
I also signed them up on here, so you may see them on here soon under the username "TydixCruiser". Hi mom and dad!:cool::cheers:
Wow, more and more electronic stuff to crap out...
The old school system still works best.
:lol: I agree. My wife's Tacoma has that system and it's a pain when you air down for the dunes. Even if you hit the reset, the light will come back on due to the spare still being aired up.:rolleyes:
I don't think they have had any more problems with it, and they are really enjoying it.
I got to drive it a little bit, and it made me jealous.:crybaby:
Sounds like a fairly fancy "parts truck" to have that them there option...
I drove our parts truck all winter with that light flashing. You get used to it after a while ;)
Fancy enough for you? :p The dealership has a pair of these all stickered up like Nascar trucks. They slide around corners quite nicely in the winter :steer:
This is not a feature, unfortunately, on my new '09 VXR Gulf Spec. I think it is a LX only item in the Gulf. Just wondering, can you possibly reset this from the Diagnostic Mode in the Nav screen? I haven't tried to reset any codes, but there is an option to do so there. Maybe someone can try and post the result.
Are you talking about the tire pressure warning system? The reset button is under the drivers dash to the left.....stick your head under there and you cannot miss it.
anyone know if the TPMS is a direct reading or the relative delta reading? Also, does it report back the value for each tire as other manufacturers do?
Not sure if it is direct or delta, but it does tell you the reading for all 5 tires, just doesn't tell you which tire is which. With a little experimenting, I was able to figure out which tire was which on the little display screen, only to forget the sequence with the last rotation I did. Oh well...as long as they are all reading ok.
Cool, thanks for posting. It's nice that the display gives you the actual value for each of the tires; the older TPMS alarmed when a certain delta amongst the tire pressures was exceeded. I really like the TPMS systems used by Porsche and Chevy that give you the pressure for each tire on a layout.
It gives you the exact value, but not which tire. So if one tire is a bit low, there is no way to specifically tell which tire is low (unless you follow Chimy's method).
