Is this correct to adjust the timing I read the other posts but I want to make sure 100% sure because I'm a million miles from any place in the middle of Cambodia and a mistake would not be good here. They never did the E1 TE1 when the checked the timing so I'm sure it wrong and now that I moved it with out a timing light it all wrong now.
"To adjust the timing you make a short across E1 and TE1 on the diagnostic connector, then adjust timing to 3-4*, remove the short, recheck (NOT adjust) to see of you get between 8 and 14*."
Brian
Brian
