timing cover
God's Country
need to know the bolt size for the timing cover. I thought it was a 36mm, but that was not. And what size sst wheel puller etc.
Thanks
sj
46mm is the crank nut...
10mmx1.25 is the thread pitch of the two bolts needed to thread into the pulley to use a puller and remove it.
:beer:
If you are talking about the nut that is on the end of the crank, and secures the crank pulley, it is 46mm or 1 13/16 inch.
I think the pulley puller bolts are 10X1.5, but I may be wrong on that.
The long oem bolt that attaches a 2F alt to the mounting bracket is 10mmx1.25...that is the bolts that I use. (you will need two) ;)
Good luck!
-Steve
:beer:
Now to find a 46mm/1"13/16 socket. I tried my retired mechanic friend. He has everything around it....Now to my dairy farmer buddy...
Any do's and Don'ts I should beware.
thanks
Scott:beer::beer:
