A few dumb questions, trying to understand the engineering behind the Timing cover/seal/timing gear and how it's all supposed to work and go together.
The cover bore for the crankshaft/seal has what looks like spiral "threads" and a small flange (built in slinger?) inside the cover around the seal housing. Are these meant to control the oil flow around the seal, getting it to move back into the cover when the shaft is turning? On mine, these big spiral "threads" have wear and a small crack, etc., which I'm guessing is not normal? Could someone have jammed the cover against the rotating pulley at some point?
Is the main, loose oil slinger meant to preload against the crank gear when the pulley is finally torqued on - or does it float loose on the shaft? Mine has a good amount of wear around the ID and I'm not sure from what?
The pulley shaft OD has what seems to be normal smooth marks from rubbing on the seal, but also deeper, cut, rotational score marks toward the end of the pulley shaft? I'm assuming those are not normal?
I'm still thinking something happened at some point in the past. Crank nut came loose, pulley came off, cam gear came apart, or maybe the seal leaked and the wrong someone went in to fix things. Something could have gotten caught in the pulley?
I'm planning on just cleaning up the cover, new seal/gaskets, etc. and getting it all back together. The wear on the oil slinger ID has made it an awkward tight fit on the shaft, maybe polish the ID?
Thanks for any feedback.
