Timing-converting from points to electronic
blunt
More ambition than motivation
Downast Maine
I have an FJ40 with points style distributor and am converting it over to electronic with a crane cams kit. Piston #1 is supposed to be at TDC for me to start modifying the distributor. I am doing this by myself and am manually turning the motor over and using a small wooden dowel to feel for when the piston is at it's top position. I am fairly new at this so I am learning as I go along.
I have a couple of questions about this method, first how do I know that the piston #1 is EXACTLY at TDC because it feels like it is there for what would be a few degrees of the turn and I figured it would need to be exact.
Secondly, since I can grab onto my distributor and turn it by hand(not real easy but can do it without too much effort), I don't think the method of marking where the contact is for cylinder #1 relative to the cap and watching for the rotor button to point at it would necessarily work in this situation.
I could really use some advice on this because I want to get this done and actually be able to start my FJ (for the first time in 2+ years, and with the newer 2f motor) next week when the new carb is delivered.
Thanks in advance,
Barrett
Ok, I opened the inspection window, turned the crank until I had lined up the timing mark on the flywheel with the indicator mark and then turned the distributor so the rotor button is pointing at my sharpie alignment mark on the #1 plug segment. I will tighten up the bolt that holds the distributor from turning and am wondering if I have solved my timing problem? Am I done?
