Timing chaing R&R
Why are you replacing the chain? Unless it is severly worn I would not change it. Unlike a small block Chevy where chain wear/stretch can cause the chain to jump a tooth or throw your timing off, the Land Cruiser has a hydraulic tensioner that takes up any stretch in the chain to prevent this.
I'd replace them all for sure if you're having issues for wear. The timing chain setup is a lifetime setup so if you've got to go in for chain replacement then something else is worn as well and you should replace it all.
DougM
