So, while I was hoping to be able to just do PM, that doesn't look like it is going to be the case.
While replacing the valve cover gasket, which I took off to replace the leaking tube seals, I discovered a broken timing chain slipper.
If not for this great forum, I wouldn't have even known it was broken. But now that I do.
I have neither the time or the ability to do this replacement. My question is this.
The dealer has quoted an astronimical price to fix the problem. The only good thing is it will definately fix my oil pump cover leak. I don't have the detailed breakdown of what they will be doing but wanted to ask a question.
I saw on the Slee site they mention that toyota calls for pulling the head and the two oil pans. If this is the case, it might explain the high cost. But, also if this is the case, then I will get my new HG, right?
See I don't think i want to spend all that money only to find out later I need a new HG. But if I am getting the oil leak fixed, the timing slipper a new HG and the pan arch sealed, then it might be worth it. yes, I know you DIY guys would choke on the cost, but I don't have a lot of options.
So, is it most likely the dealer is going to pull the head and fix that too? I can't seem to get anyone on the phone over there to respond.
